Headlights Reminder
I am a new owner of a used 2006 Chevy HHR. I traded in a Chevy Equinox because the gas mileage was so bad and it was having some problems...
On my Equinox, if I turned the lights on, it dinged when I got out of the car. In PA, state law requires lights (NOT day running lights) to be turned on in fog, whenever wipers are used, and in construction areas.
Yes, I have a manual, but don't see anything about this issue, that's why I asked the question.
I just checked my manual and on page 3-15, it says "If you open the driver's door with the ignition off and the lamps on, you will hear a warning chime."
I thought I remember testing it or hearing it before. That's why I'm wondering why it didn't go off this time. ...
and is this the whole reason my car wouldn't start???
Yes and no. I knew it uses the radio, but not that it uses only that speaker. Although I would notice if one of my seakers went out. Unless he only use the radio as a warning device, it seems an unlikely cause for his problem.
You might, but most people don't. Most only notice the lack of chime. Strange but true.
Am I the only one here that knows that you can turn off the auto headlights? It is really easy with no technical expertise. At least on my '09. Just rotate the light switch back instead of forward to turn them on. When you rotate the switch to turn the lights off, you get a message on the DIC saying AUTO LIGHTS OFF and the chime comes on for a couple of dings. Also, if you hold the info button and the scroll button at the same time for the DIC display you can reprogram what you want to happen when you lock and unlock the car. My headlights used to come on automatically when I unlocked the car, now they don't. Plus I programmed it to beep when I locked the car, this won't happen if the lights are left on. This is also how you reset the oil change on the car. It is all in the owners manual. At least for the '09 it is.
