Heater fan and rear wiper
Got into the car today for the first time in a week. Was laid up for knee surgery. The heater fan only works on it's highest setting. I did a search and didn't find any matches, anyone else have this happen?
Also, the rear wiper has about a 2 second delay when it is on continuous setting, is that the same all over, this one has been like this since new (15,000 kms now, got it in July). I will be bringing it in for it's second service next week. Going for synthetic oil this time.
The rear wiper is about 5 sec. between cycles.
That makes sense pitbull.
Brakes got the shakes again, already had the rotors done once at the dealership, will end up just replacing them with slotted ones.
someplace there is a thread on the fan, just like your. believe the motor had to be replaced. found it
https://www.chevyhhr.net/forums/problems-service-repairs-42/heater-fan-control-problem-12143/
hope the knee is feeling better. been there.
If the rear wiper is moving slowly:
The Vues have a problem with the rear wiper motor being so jam packed with grease that the gears can hardly move after a while...The dealer will simply replace the motor. But is you're out of warranty its a $400.00 job at the dealer. On the Vue, we take the motor off of the rear wiper, open it up and clean out all of the grease. Then we lightly regrease it and put it back into service. It usually solves the problem if there's not a broken gear in there.
Just had mine in the shop not too long ago for the same fan problem, blown resistor, i guess its fairly common for some gm vehicles. Takes a little while to fix, I had to leave it overnight. The rear wiper normally has some delay as it is, so i think thats normal. Good luck man!
My 2001 and 2003 Malibus both had the failure. If it's out of warranty, you can do the fix yourself, provided you have the skills and are flexible enough to do some Cirque du Soleil acrobatics to get yourself in position
