Help!!
Old 03-06-2008 | 03:23 PM
08HHRlover's Avatar
Help!!
I'm new here and I need some help. My front window has had moisture on it twice now. Last time I took it to the dealership, they said they took care of it. It happened again yesterday and they checked it today and said they couldn't find anything wrong. Anyone else have this problem??? I need some help here!
Old 03-06-2008 | 03:31 PM
HipHotRod's Avatar
"front window has moisture on it" Thats a little vague friend, can you be more specific? Are we talking windshield? What kind of moisture? Inside? outside? Tell us more about the problem.
Old 03-06-2008 | 03:41 PM
SIRESMERPH's Avatar
yep, a lil more info please
Old 03-06-2008 | 03:46 PM
ChevyMgr's Avatar
This may help the dealer fix it. The bulletin number is in blue. What did the first repair order say they did?
#07-08-57-001B: Water Leak, Front and Rear Carpet Wet, Mildew Odor When A/C is Turned On or Blower Motor Inoperative (Reseal Body Seams) - (Nov 29, 2007)
Subject: Water Leak / Front and Rear Carpet Wet, Mildew Odor When A/C is Turned On or Blower Motor Inoperative (Reseal Body Seams)
Models: 2006-2008 Chevrolet HHR
This bulletin is being revised to include an additional water leak concern at the outside mirrors. Please discard Corporate Bulletin Number 07-08-57-001A (Section 08 -- Body and Accessories).
Condition
Some customers may comment on the following concerns:
• The carpet is wet.
• The HVAC blower is inoperative.
• There is condensation on the windshield or side glass.
• A mildew odor when the A/C is turned on.
Cause
These conditions may be caused by the following:
• Air bubbles in the body sealer (front of dash).
• Module plate not sealing.
• Front body hinge pillar not sealing.
• Leaking cowl air inlet butyl patch.
• Door water / dust deflectors.
• Mirror retention clip not sealed.
**We have found that the cowl inlet butyl patch is the most common cause of condensation on the windshield. This is located under the plastic cowl cover (where the wiper arms are). This butyl patch is suppose to keep water/moisture out of the air inlet ducts.
Old 03-06-2008 | 05:11 PM
an08HHR's Avatar
I've had moisture on windshields for yrs. Car sits out side on a winter day and if the sun shines (not much in Oh in the winter) moisture forms on the inside of the glass from the snow that my feet introduced to the floor matt.and freezes at night. It was better when I had window vents shields and opened the windows a crack but my HHR doesn't have the vent shades and as long as it is cloudy it is fine. You may just have normal moisture at this point and not the water leak problem Chevy Mgr mentions.
Old 03-06-2008 | 06:12 PM
pg318's Avatar
I've had a little issue with this recently, but my carpets are dry - apart from the smow-filled rubber mats.
Old 03-06-2008 | 09:57 PM
jeffs396's Avatar
fellow Ohioan! Good luck with the water issue, I'm sure you'll get it sorted & enjoy the HHR again! Check out the Cedar Point thread, maybe you can join us in July!
Old 03-06-2008 | 10:12 PM
Definately not AC related, unless the AC on his HHR is roof mounted.
BTW 08HHRlover..........
Old 03-07-2008 | 11:28 AM
08HHRlover's Avatar
help...
It was just moisture on the inside of the window. There was snow and it was sunny...so that could have been it. Last time, they said they had to sand something down in my heating/ac system. This time, "they couldn't find anything." who knows...
Old 03-07-2008 | 11:30 AM
08HHRlover's Avatar
That's what it was, condensation on the inside of the front windshield.
