Help!!
Help!!
I own a 2006 hhr. Jus recently did a full tune up and oil change. Replaced exhaust and cam shaft sensor as well. Always keep up on oil changes and reg maintenance. Never really had any major issues with it til sunday night. I was driving and about 30 min into my commute i noticed a loud noise from under the hood. I get to my destination and its still making the same noise. Had to drive it back home that way. I noticed the temp is up about 20-25 degrees higher then usual not overheating though. Get it home and park it. Wake up in the morning and theres a lil leakage in my driveway along with the one in my friends driveway. Now i'm told theres no oil in it and theres oil in the coolant as well. I have no idea what could've caused this or where to start looking. I'm told its not the water pump and theres so much leakage its hard to see where its originating from. IT IS A 2.4 ENGINE AND A MANUAL TRANSMISSION. Anyone have the same or similar problem before..?? Any suggestions what it could be..??
Any CEL? Look more carefully for the location of the leak. Does the engine seem to run normally? If you have oil/anti freeze mixing the most common/possible issue would be a bad head gasket. If its leaking that fast, a compression check may help narrow it down.
The statement "theres no oil in it" is BAD! Reading your other descriptions, it's sounds as if you're not mechanically inclined, so.........
First. Don't drive it. Don't even crank it. Have a mechanic or technician look at it. Get it towed if you have to. Sounds like you have a major part or parts failure.
If you drove it with no oil, then it's most likely a goner as far as a rebuild.
FWIW. If you ever hear a loud noise from under the hood,please pull over and check it out. If you continue driving, you will only add to the damage.
X 2 to George's comments.
Hate to welcome you to the forum be seconding an opinion of catastrophic engine failure, but you've got a blown engine on your hands.
Have it hauled to your dealer or mechanic.
(snip) I was driving and about 30 min into my commute i noticed a loud noise from under the hood. I get to my destination and its still making the same noise. Had to drive it back home that way. I noticed the temp is up about 20-25 degrees higher then usual not overheating though. Get it home and park it. Wake up in the morning and theres a lil leakage in my driveway along with the one in my friends driveway. Now i'm told theres no oil in it and theres oil in the coolant as well.
(snip)
(snip)
It's likely you're looking at minimum a head gasket and perhaps a new engine.
