Help!
Old 10-14-2014 | 07:20 AM
Welcome to the site! Now double chech that suspension up front!
Old 10-14-2014 | 08:20 AM
Just because hub was the first thing that came to mind does not mean that's where to throw your money.
Sounds like you lack some experience & knowledge with suspensions, maybe paying for a alignment to find out what's broke would save you in the long run. If something is broken or worn DON'T let them make adjustments, you'll be back.
Old 10-14-2014 | 11:39 AM
Twistedtat's Avatar
Welcome to the site. X-3 as to what everyone said. One more thing to check for the sound.
Strut mounts make noise when bad also.If the bearing is bad it will make a grinding sound. Or mine did at least. Not sure if hitting a curb would damage it.
Let us know how it goes and good luck.
Old 10-14-2014 | 11:54 AM
LawDog88's Avatar
Did to mine...
Old 10-14-2014 | 12:43 PM
There are as many different descriptions of the sound a bad hub makes as there are the sound a bad flex pipe makes. And that number is very close to the number of navels there are.
