Help with alignment question, tire wear
Old 06-21-2019 | 05:37 PM
mamerc's Avatar
grandson hit a curb taking out both lower control arms and front wheels a few months back. I replaced them as well as the front bumper cover. The car only has to last a few months then he goes into the Marines. The new wheel comes in today, I will make a decision about what we will do next week. If I can get another axil cheap, I will replace it. Not sure what that bent wheel did on the alignment readings., what are the chances it now will come closer to spec?
Old 06-21-2019 | 06:07 PM
You can't even properly check alignment with a bent wheel, so all previous readings are null and void.
Old 06-23-2019 | 03:08 PM
Blue_SS's Avatar
Bent parts need to be replaced. The cradle shift is not that tough to do - on a lift... You just loosen the cradle, shift it to the correct side and re-secure. You are looking for about a 1/2" shift or so. You can't do it with weight on the front wheels though. Camber bolts might also work if you can find them in the right size, but they are band-aid.
Franco Fanfuria
08-28-2014 08:22 PM
JPJ9
36
12-01-2013 04:09 PM
hozer
08-18-2012 02:46 PM
Neal Sweeney
05-21-2010 06:31 PM
edb
07-26-2008 12:43 AM
Quick Reply: Help with alignment question, tire wear
