HELP!! Chevy Malibu 2003 p0300
Hi guys,
I really need help I got a car 4 weeks ago I brought a car (03 Chevy Malibu base 142k mil, 3.1L V6) and the check engine light was on, so it was no way for me to pass state inspection. I replaced the battery, did a oil change and a coolant flush. Went over to autozone and had them scan it for me and code p0306 was coming up, so I changed the spark plugs in the front cylinders (2, 4, 6) and the wires.
So I went to a shop to have them inspected it and put a sticker on it. But it failed, so the shop started working on it to get the code to clear, first they changed the coil pack thin the injection valve, nothing worked thin they checked the locker arms in the motor and seen that one of them was broken and lost the thread.
They replaced it thin seen it messed up a piston and they replaced that. They started it back up and the p0306 code was gone and now they say its giving a p0300 code. I got feed up and got my car back, the next day i started it up to take it to a different shop. but before i got out my driveway it cut off on me two times. i got it around the corner and it was running good at fast speeds but as soon as i slowed down at a sign it started shacking bad and cut off.
i called the shop that just worked on it. and said why is it now cutting off on me they told me to bring it back in. a week later and they are saying my number 6 cylinder has low compression. so they put a little oil in it but they are still getting low compression in that cylinder. are they milking me for money or are they going in they right direction?
Welcome. BUT, this is the HHR forum. We don't know from V6.
It sounds like they are going to tell you that you have a burned valve in #6. Next test would be a bore scope, most likely.
Are you aware that this is a forum for the Chevy HHR, all of which have 4 cyl ecotec motors, not the chevy V6?
With the number of problems you have had, and the number of repairs and parts replaced (seriously - they replaced a piston?) - I'd say cut your losses and get rid of it.
Or are you tolling?
Or are you tolling?
Try our sister Chevrolet forum, membership is free, and they have a dedicated Malibu Sub-Forum.
Click the link below, and good luck....
Malibu - Chevrolet Forum - Chevy Enthusiasts Forums
