HELP! HHR wont start.
Old 11-12-2014 | 07:33 AM
Grizzly old man's Avatar
Yes, there is a plastic plug near the middle of the hatch door. You have to pull it out of hole it lives in then use a screw driver to feel around until you hit the manual release for the door.
Old 11-12-2014 | 07:48 AM
Okay grizzly,I give. What's the connection between the brake cable and battery cable.
I get the feeling something is left out. Things don't make sense.
Old 11-12-2014 | 07:52 AM
He said he pulled the parking brake and slid into his parking spot at work. I figure he may have had something loose in the battery area that might have caused his problems.
On my '06 I seem to remember seeing a smaller wire attached to the positive battery cable that had something like a fuse in it. If he managed to damage that wire I don't think the car will start.
Old 11-12-2014 | 07:58 AM
PaperChaseHHR's Avatar
Just checked battery connections are all clean and firmly attached. Checked the red fuse in the trunk and is fine. Car is still doing the same thing.
Old 11-12-2014 | 08:11 AM
Well, I'm stumped then,... may be time to call the hook and have it taken to a shop.
Old 11-12-2014 | 08:19 AM
Until you get a multi meter and start checking the voltage at certain points, all you're doing now is trying to get lucky and find a loose connection.
Start at the battery then work forward.
Fwiw. The airbag light being on. It should always come on when the ignition is turned to the "On" position. It may not complete it's status check(then turn off) IF the car does not start.
Old 11-12-2014 | 08:23 AM
I've been sitting here smoking my pipe and drinking some coffee and thinking about this. I wonder now if maybe the neutral switch might have gotten out of position.
I still wonder why you decided to use the parking brake to slide in to your parking spot but kinda figured you might be young enough to think it was just fun.
Old 11-12-2014 | 08:32 AM
LawDog88's Avatar
^^ Yes. I've been guilty of this too. But I no longer do. IT hurts the suspension a fair bit, and I like my Ride.
Didn't catch if it was mentioned. 5sp or Auto?
Grizzly old man - yea every once in a while ill rip it lol, have to ensure it works ya know?
Well I guess ill give Jeff Wyler a call and see what their service dept has to say..
I will continue to post on here until it gets solved, and also as to what Jeffy Wyler says.
Old 11-12-2014 | 08:33 AM
Auto
Quick Reply: HELP! HHR wont start.
