HELP! HHR wont start.
Old 11-17-2014 | 12:19 PM
  #31
Well, that'll do it for sure. Glad you got it found out. It would be great to know where it broke, and why. That is a first as far as I know.
Old 11-18-2014 | 09:39 AM
  #32
PaperChaseHHR's Avatar
Picking it up today, ill ask where it broke and the possibilities of how it occured. I'll post on here after the information is recieved! Im thinking that maybe my battery strap was loose or maybe not fully bolted and when I ripped the e-brake the sudden jolt when the tires regained traction is what broke the wire.
Old 11-18-2014 | 10:14 AM
  #33
LawDog88's Avatar
More likely the jolt of regaining traction in the rear depending on the angle and amount of G's your pulling, I would more suspect cracked bolt platform for base of battery, OR depending on the momentum, perhaps a cracked battery, more than the cable. Something doesn't seem to add up right to me.
Old 11-18-2014 | 11:41 AM
  #34
Me too Kev. And I'm still trying to comprehend the OP's statement:
"WE HAVE FOUND THE ISSUE! Broken main battery cable... SERIOUSLY?!!!"
The earlier posts said it had battery power to the car electronics, just would not turn over the starter.
Hmmm. If it was a broken main battery cable, then how was there power up front ?
Who knows. Maybe it's just me and my reading comprehension.
Old 11-18-2014 | 12:28 PM
  #35
It's possible that it was still making contact, but not enough to allow a high current such as the starter motor to operate properly, but would allow a low current draw only.
I had a similar issue working on an old golf cart recently where a bad connection from the cable to the post clamp was rather nasty, and due to the poor connection, the area around the bad connection would glow red hot when it was subjected to a heavy load. Cleaning it up and cutting back the wire to a "clean" spot resolved that issue.
Old 11-18-2014 | 02:04 PM
  #36
Exactly whopper.
As you stated with the golf cart it was a "bad" connection. Not a broken connection.
The OP used the term "broken" main battery cable.
See how I interpret this ? Hell, maybe it's just my southern, good ole boy accent that misunderstands the way people write things on the internet.
Old 11-18-2014 | 03:04 PM
  #37
There are two red wires off of the battery.
Old 11-18-2014 | 03:19 PM
  #38
LawDog88's Avatar
Cables
whoweth
07-01-2015 03:00 PM
kalifdave
02-09-2015 08:21 AM
cccjoh
05-16-2014 10:00 PM
Shanes0406
11-08-2012 12:37 PM
upOnGamE
10-05-2006 08:08 PM
Quick Reply: HELP! HHR wont start.
