Help! I broke a bolt
Old 08-28-2022, 02:17 PM
Canis_maj0ris's Avatar
I have a 2010 HHR 2.2 Manual trans. I was replacing the front lower engine mount and snapped one of the bolts. The lowest most bolt is the one i snapped. Does anyone know the exact size and where I can get one?
Canis_maj0ris is offline
Old 08-28-2022, 03:42 PM
greg8453's Avatar
Take it to the hardware store and they will be able to match it.
greg8453 is offline
Old 08-28-2022, 03:46 PM
hurst2001's Avatar
Dealer probably
hurst2001 is offline
Old 08-28-2022, 04:06 PM
to the forums!
I can't even find a part number. Take it to your GM parts department, they should be able to identify it and order it. They may even stock it.
RJ_RS_SS_350 is offline
Old 08-28-2022, 04:46 PM
X2 take both pieces.
Oldblue is offline
Old 08-28-2022, 04:50 PM
Go to a GM dealer, tell them where it was and show it to them.
donbrew is offline
Old 08-28-2022, 05:42 PM
Here's the problem, that bolt isn't even shown on the diagram. The other 2 are shown, but notice that the identifying numbers differ (#14 and #15 ) hinting that they may be different from each other. Usually (not always) if it's the same part number, the identifying number will be the same.
Even then, the other 2 bolts are not listed, no part number, no description, nothing.
You could remove the other 2 and see if 1 of them match the broken one. At least give the parts guy a fighting chance. Or go to a wrecking yard (pull-a-part, etc.)
Old 08-28-2022, 07:05 PM
Isn’t it bolt 10 ? Or maybe 12? Front lower mount?
if it’s the bolts for the engine mount there are two like #14 and one #15 it’s shorter
Oldblue is offline
Old 08-28-2022, 07:19 PM
He did say engine mount. The rest are transmission mounts.
Ok, if it is indeed engine mount, then it's #14, that'll give the parts guy something to look for.
Old 08-28-2022, 09:26 PM
Yeah your right it's a transmission mount, my bad
Yeah it doesn't show it, i went got a bolt from the hardware i only went in half way. May the threads are shot?
I was only tightening it by hand ( the bolt i got from hardware store) it seemed to get jammed up about half way i didn't want to push it, maybe mess up the thread in hole
Quick Reply: Help! I broke a bolt
