Help! I broke a bolt
I have a 2010 HHR 2.2 Manual trans. I was replacing the front lower engine mount and snapped one of the bolts. The lowest most bolt is the one i snapped. Does anyone know the exact size and where I can get one?
Here's the problem, that bolt isn't even shown on the diagram. The other 2 are shown, but notice that the identifying numbers differ (#14 and #15 ) hinting that they may be different from each other. Usually (not always) if it's the same part number, the identifying number will be the same.
Even then, the other 2 bolts are not listed, no part number, no description, nothing.
You could remove the other 2 and see if 1 of them match the broken one. At least give the parts guy a fighting chance. Or go to a wrecking yard (pull-a-part, etc.)
Yeah your right it's a transmission mount, my bad
Yeah it doesn't show it, i went got a bolt from the hardware i only went in half way. May the threads are shot?
I was only tightening it by hand ( the bolt i got from hardware store) it seemed to get jammed up about half way i didn't want to push it, maybe mess up the thread in hole
