Help With Silly Battery Cable Ends
Old 04-02-2011 | 07:31 PM
jonboyb's Avatar
Nah.....you'd have to see it to understand what I'm describing I guess. According to my dealer, they started this in 2008 on the HHR but he's been known to be completely full of it from time to time
Old 04-03-2011 | 09:39 AM
Don06's Avatar
Originally Posted by jonboyb
That's what I did.....well actually stole the cam from the negative side and then replaced the short negative cable with a standard one. Just fear my dealer will see if I ever have to go in for electrical issues and claim it was my fault putting the new cable in
Shouldn't be a problem. If you're worried about it, buy a new ground cable, the short one.
Old 04-03-2011 | 10:04 AM
jonboyb's Avatar
The short ground cable is only available as a 2-piece set including the 15' ground to the engine bay. In fact, it's more than the positive (at like $240)
Old 04-03-2011 | 10:10 AM
Don06's Avatar
Now that's just insane!
Old 04-03-2011 | 06:58 PM
stanvalp's Avatar
where do the cables run from back to front? inside passenger compartment or under car/
Old 04-08-2011 | 06:17 PM
Sno White's Avatar
Mostly inside the passenger compartment under the rug – don’t know where it penetrates the firewall.
Old 04-09-2011 | 09:42 AM
Laco's Avatar
Seems like putting a new end on existing cable would be the way to go. Probably one with a standard connector. When I get a chance, I'll check my 2007 to see what type connectors it has.
Greylotus11
01-18-2013 10:16 AM
JRGHHRSS08
11-14-2010 06:28 PM
Lone Ranger
08-04-2008 01:36 PM
inchworm
04-13-2007 06:14 AM
Quick Reply: Help With Silly Battery Cable Ends
