HHR Battery Too Weak for Winter
I'm getting tired of coming out to my (garaged) HHR and finding the battery either stone dead, or insufficiently charged to start the car. It's been pretty cold lately.
I'm thinking of installing a trickle charger and plugging the car in overnight.
I was also wondering if there was any experience with putting larger batteries in the HHR.
Thanks,
Ed G
Thanks,
Ed G
Well, no as the compartment is only so big, I suggest you check your battery, depending on how old it is, it could be on it's last legs.
My 3 1/2 year old battery had a dead cell in it, so I would have it checked , many parts stores will test it at no charge. it could also be your alternator, or your serpentine belt.
ensure you get the correct battery for the HHR, with the vent tube connected correctly.
ensure your connections are clean and tight. Check your ground connections at the trans and rad cradle are also clean and tight.
Time for an AGM battery...
https://www.chevyhhr.net/forums/comm...battery-52505/
edgreenberg.......if you replace the battery I would still use a trickle charger at night.....best thing to insure reliability.
Been there, done that
I should have mentioned that the battery was replaced December 2013. The car is a 2011. The terminals were all cleaned, both front and back of car when the battery was changed.
It was -12 degrees overnight before the no-start.
I'm going to check the voltage now that the battery is charged and the car has started. Assuming I don't suspect a dead cell, I'll start with a trickle charger.
Thanks for all the suggestions.
Ed
Ed
Ed
Ed
Ed- a 'trickle charger' must not be left on too long or it can over charge it, & boil out the acid. Killing the battery..
I would suggest looking into a "Battery Maintainer" such as a Deltran Battery Tender Jr.
These are smart chargers & you just hook up & forget it.. Once they achieve full charge, they swtch to Float mode, maintaining your battery @ 100%.
Cost for one is about $24. on eBay
I have a couple of these that are old now but still working perfectly. They are .750mA ....
Another option is a Battery MINDer* which I have 1 as well.. 1.5mA
My HHR is still on the OEM battery installed 11/07 (build date)..
