HHR Battery Too Weak for Winter
Old 01-15-2015 | 12:20 AM
Originally Posted by sleeper
Ed- a 'trickle charger' must not be left on too long or it can over charge it, & boil out the acid. Killing the battery..
I would suggest looking into a "Battery Maintainer" such as a Deltran Battery Tender Jr.
These are smart chargers & you just hook up & forget it.. Once they achieve full charge, they swtch to Float mode, maintaining your battery @ 100%.
Cost for one is about $24. on eBay
I have a couple of these that are old now but still working perfectly. They are .750mA ....
Another option is a Battery MINDer* which I have 1 as well.. 1.5mA
My HHR is still on the OEM battery installed 11/07 (build date)..
Excellent info sleeper.
Old 01-15-2015 | 12:45 AM
x2 - I use a similar "maintainer" on the M/C - got 6 or 7 years out of my last battery before I chickened out and got a new one.
The standard sized battery for the HHR is sufficient for most weather conditions one is likely to encounter. A battery heater may be needed in severe cold as per recommended to Britjoe a while ago - but most likely is overkill unless your vehicle is being left out in -10 to -20F temps.
A failing battery, or defective battery, or a fault in the electrical system is IMO the general cause of the similar issues we have seen on the forums here.
but I may be wrong
Old 01-15-2015 | 01:00 AM
Originally Posted by whopper
but I may be wrong
We're never wrong whopper, we're just occasionally saddled with a case of "Momentary Imperfection Syndrome".
Old 01-15-2015 | 01:16 AM
... and the ad at the top of the page is the Battery Tender!!! Nicely done :)
Old 01-15-2015 | 06:24 AM
Focused advertising. The ads usually have something to do with what you are reading.
Old 01-17-2015 | 07:20 AM
08HHRPA's Avatar
I just replaced the factory battery in my '08. I could have done it last year, but it's been OK until now; it was starting to get sluggish on cold starts in single digit temps. Our winters get a few times where it's subzero for a few days, but mostly single digits or low teens in mid winter.
I got a Gold level battery from Advance; I've never been impressed by Walmart batteries. I had a $20 off coupon and timing was right, so now it's done.
docwatson
10-04-2014 01:56 PM
jeffros hhr
02-13-2010 02:31 PM
slantram
11-14-2009 10:44 PM
20vtguy
10-30-2007 09:29 PM
chitownbro1
09-30-2007 08:11 AM
Quick Reply: HHR Battery Too Weak for Winter
