HHR Key stuck in the ignition
I have a 2006 HHR and the key is stuck in the ignition. From what I read on other threads it is the shifter linkage. I have found some on E-bay to replace it and I was just wondering if one from a 2011 will fit it?
Thanks,
Don
Thanks,
Don
recall on this
this is how you get the key out
this usually is the problem and fix
http://www.yesteryeardepot.com/SP2921.JPG
to the forum Don!
It wasn't a recall exactly, but a Customer Satisfaction Campaign on GM's part. I believe that the '06 model year HHRs were excluded, but GM seems to still be handling this on a case by case basis for non-covered vehicles.
Talk to your dealer's Service Manager about a "Goodwill" repair.
Here's the thread on the Campaign letter....
https://www.chevyhhr.net/forums/problems-service-repairs-42/letter-gm-ignition-lock-cylinder-41009/
If I remember correctly there is a TSB on the 2006 model, with pics. Maybe it was just another thread, try the SEARCH. I am pretty sure that somewhere on here I've seen reference to a design change after 2006, and I know I've seen pics.
Try these posts on shifter removal and repair.
https://www.chevyhhr.net/forums/problems-service-repairs-42/auto-shifter-removal-43855/
https://www.chevyhhr.net/forums/show...hlight=shifter
