HHR overheating
Old 01-22-2014 | 07:46 AM
Says right on it, "HP Tuners". Also Check out "Torque" and "ScanMaster"on Google Play & I think I-phone now. PM me if you want a PC solution.
You will also need an ELM 327 adapter, available on E Bay for $15-$20. There are a few different ones in either BT or USB, they are all made in China and have bad QC so purchase from a dealer with free returns. The "made in USA" versions run in the over $100 range.
Old 10-27-2018 | 02:14 PM
Mikey269's Avatar
If the fan dont kick on till 223 i would like to think not many hhr fans have ever been used... If your hhr goes over 200 on a regular bases something is definitely wrong. Thermostat should open or something. Soo will be nice to know what the issue is
Old 10-27-2018 | 03:15 PM
You're responding to a post from over 11 years ago.
Summertime, stop and go traffic, you'll see temps over 200* regularly. Not a problem as long as the coolant doesn't boil. With a pressurized system + coolant, the boiling point is raised significantly.
Old 10-27-2018 | 04:43 PM
Idling in garage will Get it to 220F.. It is setup for fuel economy which is best between 180F and 220F while moving.
Mine rarely goes over 220F while driving in hills at high speed
guppy
08-24-2015 07:29 AM
batsibf
2.4L Performance Tech
14
04-26-2015 11:22 AM
cturboaddict
08-18-2013 09:15 PM
Mr Z
07-27-2012 05:26 PM
TxSkyPilot
01-28-2008 04:54 PM
Quick Reply: HHR overheating
