HHR Panel Rear Door Popper problem...HELP!!
Old 12-18-2017, 05:11 PM
Milton Grimes's Avatar
Good evening everyone. I purchased a 2010 Chevy HHR panel with the intent on using it for my business. However the rear door poppers don't work. I have to manually open the doors by reaching my hand through the front door to the rear handle. It doesn't seem like the buttons on the dash or the remotes are triggering the doors to open. Could this be a power issue? A BCM? All of the above? None of the above? I've tried checking the fuses in the main fuse panel under the hood as well as the fuse panel under the center console but everything seemed to check out. Am I missing anything?
Milton Grimes is offline
Old 12-18-2017, 05:29 PM
Welcome to the site, perhaps the poppers are sticking, the door hinges are in need of a good oiling!
Loose wires and ground wires can also cause problems
Oldblue is offline
Old 12-18-2017, 05:31 PM
The poppers aren't making any noise at all. I bench tested the poppers and they work fine. It seems to be an issue in the car. I'm looking for a little guidance on where to start.
Old 12-18-2017, 05:35 PM
relay(s)?
There is a possibility that someone that did not know what they were doing messed with the programming.
donbrew is offline
You’ve done step one now trace back the wires until you find the issue.
Myself I would check the dash board switches.
I’m looking into wiring diagrams for you.
Oldblue is offline
Old 12-18-2017, 05:39 PM
Thank you. A wiring schematic would certainly help. Are there any additional possible fuse or relay locations other than the 2 main fuse panels?
Old 12-18-2017, 05:50 PM
Look in your owners manual. If you don't have one, there is a link for them above in Donbrew's signature.
I found this. May help.
firemangeorge is offline
Old 12-18-2017, 05:53 PM
Yep, they beat me to it!
Oldblue is offline
Old 12-18-2017, 06:10 PM
Make sure yours exist. There is also a relay block in the Rrear quarter panel area. And that extra fuse near the battery.
One of these is for "release" the other is for "lock". I am guessing "release" is the poppers.
donbrew is offline
Old 12-18-2017, 06:55 PM
Do you have the legend for this schematic?
Quick Reply: HHR Panel Rear Door Popper problem...HELP!!
