hhr power brake vacuum line freezes ?
if the check valve is not working condensate/moisture could be pulled back into the booster from the engine after shut down.
your booster may have a lot of water in by now.
some foreign cars where having similar problems with booster line icing. a redesigned check valve was the cure.
badassbowtie
02-15-2013 08:25 PM
