Hhr pulls to right when driving
could be anything from a low tire to worn suspension parts. Start with the easy stuff. check air in tires and wear on tires, then look for worn or sloppy suspension. wheel bearings, LCA bushings, tie rod ends, sway bar links and mounts, etc.
does it happen all the time or when applying brakes or ??
Thoughts
Well I had spacers put in and it seemed to be the spacer because when they swapped it to the left it pulled to the left so I told them to just put the spacer in the back and now the alignment is fine because everything is fine the alignment was checked nothing was wrong no worn Parts all the suspension parts were good so apparently something in the space or was off which was really weird because they said they never heard of that before so I'm not shocked I'm usually always at first for everything
Another reason to avoid spacers. I assume you have some reason for them; they can be dangerous; alters the steering geometry, can keep the lugs from fully tightening, can have bad effect on the bearings and tire wear by altering the fulcrum etc. Not needed with the correct size tires. Just a bad idea for road cars, fine for show.
If your alignment guy is smart enough he may know how to deal with the altered geometry; I would not count on it. Most don't even inspect the LCA bushings.
Hi
So I had one Inch spacers put on all four tires and they look amazing they switched them up a little bit and put the front in the rear and now I don't have a pole anymore so I like the look of it it makes the car look more aggressive I've done it on other cars that I have and it doesn't affect anything with the car it just gives it a more aggressive stance
