HHR putting and turns off at low speeds
Old 08-24-2019 | 10:46 PM
Benito Murillo's Avatar
Just curious.
1st post says it's a 2006 LS with a 2.4. Could you even get that combo model/engine back then ?
I fixed it, it's a 2.2 ls. The LT can have the 2.4
Old 08-25-2019 | 05:23 AM
Originally Posted by Benito Murillo
I went ahead and changed the sparkplugs since they were almost at 100000 miles and they were either white or black at the spark end. .
Just for clarification... Are you saying some were white while others were black? If so, did you keep track of what cylinders they each came out of?
Old 08-25-2019 | 10:21 AM
Oops I don't remember which one was white and which was black but I remember it was alternating. ie white plug, black plug, white plug, black plug.
I also noticed every time the engine putts it pulses like cabin lights with each one.
Old 08-25-2019 | 10:50 AM
Faulty engine ground
Old 08-25-2019 | 04:50 PM
Thanks you for everyone's help. I just checked the codes since I just got home from work and it has a p0326 (knock sensor) bank 1 code pending. I also noticed the putting has become way more frequently as o was driving home
Old 08-25-2019 | 05:16 PM
That doesn't necessarily me the sensor is bad... It means it's sensing something bad.
Old 08-25-2019 | 07:30 PM
The P0326 means the ECM commanded spark retard at a given load and speed is more than the calibrated value. I.E.: there is a knock.
Old 08-26-2019 | 10:28 AM
Is there a way I can figure out the cause of this at home? It seems to only knock at idle and in first gear, then disapears at speed
Old 08-26-2019 | 10:59 AM
Check the knock sensor, is it tight? Connections clean and tight?
Old 08-26-2019 | 12:15 PM
The knock sensor is essentially a microphone. If there is something banging from vibration it will sense it as a knock.
brant petty
15
05-27-2019 08:06 AM
Dhorning23
2.4L Performance Tech
02-04-2017 09:56 PM
Dev Anthony
03-15-2016 02:04 PM
goetylsd
01-19-2015 10:11 AM
BogusOtis
01-01-2014 08:38 AM
Quick Reply: HHR putting and turns off at low speeds
