HHR randomly flashes brights on and off while not touching control arm
Old 03-29-2014 | 01:16 AM
slothmonxtr's Avatar
My wife has been having a problem that just started. While sitting at a stop light she noticed her high beam indicator light would randomly flash on and off. She later noticed that her high beam lights were actually flashing as well. This all happens while not putting any input in the steering wheel or turn signal arm. Any ideas what may be causing this?
Old 03-29-2014 | 01:43 AM
I see from your profile that you have a 2007 model, so check the "High Beam" relay in position #72 in the underhood fusebox. With the vehicle running and the lights on, you may hear the relay cycling rapidly, if it is...you've found your culprit.
I had a similar failure on my '06 with virtually identical symptoms.
If you're missing your owner's manual with the fusebox diagrams, click the link below and then your model year to download a free copy in PDF form.
https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
P.S. to the forum!
Old 03-29-2014 | 03:53 AM
Lucky's Avatar
Welcome to the site.
I agree with above the relay is a good place to start
Old 04-11-2014 | 02:50 AM
So I am learning more about this each day and it seems to be more consistent. I'm finding I'm also super slow to respond as well.
Since my last post I have found that something is draining the car battery. I found today that the high beam indicator light is always on now and the radio's lights are always on. I located the previously mentioned relay. In touching the relay I found it was really warm so I removed it. I found that the high beam indicator light and radio lights stay on but now the actual high beam headlights are off. After removing this relay I left the car sitting. I returned a few hours later and found the indicator light and radiolights were still on and my battery was actively draining. I also removed both high beam fuses, but have the same results.
I also tracked down the fuse for the radio and removed it. Now the radio lights and the key fob don't work. Hoping this will save the battery until I can figure this out.
Old 04-11-2014 | 07:21 AM
Disconnect the negative battery cable for 20-30 minutes. That might reset the BCM, at least it's a free try.
Old 04-12-2014 | 12:31 AM
No change after disconnecting the battery then reconnecting after 30 minutes.
Old 04-12-2014 | 09:56 PM
Did you get a NEW relay? If it was hot, it is most likely fried. maybe some other relays and wires, also.
These things are very difficult to deal with remotely.
Old 04-13-2014 | 12:40 PM
Don06's Avatar
I'd suspect the dimmer switch on the turn signal stalk or the wiring to it. I assume that the wire that turns on the high beam relay also turns on the high beam indicator.
Old 04-14-2014 | 08:43 PM
Well I bit the bullet and took it to the dealer. Turns out the controller on the steering column was faulty. Thank you for your help and ideas. Problem should be corrected by morning. :)
vettman
03-19-2015 04:03 PM
Marketblandings
06-09-2014 03:20 PM
jdjaa1959
08-12-2013 05:34 PM
synthkid
03-20-2013 03:33 PM
A Crazy Canuck
02-12-2013 12:52 AM
Quick Reply: HHR randomly flashes brights on and off while not touching control arm
