HHR Rattling sound when driving over uneven surfaces
Old 01-07-2007 | 11:33 AM
Black Rose's Avatar
My steering wheel is just slightly off centre to the left (came from the factory that way).
I have an odd metallic noise in the steering column that goes away if I put upward pressure on the steering wheel, but only when the interior is cold. Goes away once the interior is warmed up (at least it seems that way).
glb, seems odd that they would charge you for an alignment after doing steering work.
With the dealership I go to, if any of the front end components are changed (PS rack, ball joints, tie rod ends, etc) they automatically do an alignment as part of the warranty work.
Old 01-14-2007 | 05:55 PM
accaptain's Avatar
I purchased mine used 10,000 miles and the steering wheel was pretty far off center to the right. I worked out on purchase for the dealer to fix it. Next day after purchase they did a front end alignment and now its perfect!
Old 01-15-2007 | 09:42 AM
glb's Avatar
glb
Black Rose, Understood..thus the shouting match in the middle of the the service Dept with all of their customers watching in disbelief! Gm actually contacted me and researched the incident. Received a call from the dealership immediately after GM contacted me. My parts would be in the next day and the car would be ready for me. Well, parts came in (this was on a Tuesday) and car was not ready until Friday. Heaven knows what else they had to do to it, but I pretty much have an entire new front-end..the rattle is gone, and the car drives like a champ now. The steering ended up much tighter than it's ever been and feels much more solid than it used to. I'm supposed to call GM back and let them know how the vehicle is. They promsed to compensate me for what I had to pay out-of-pocket. I'll let you all know how it goes.
GB
Old 01-15-2007 | 09:50 AM
glb's Avatar
glb
accaptain..My steering wheel was perfectly fine up until they did the "fix" When they replaced the intermediate shaft for whatever reason my steering wheel ended up off center. Wheel alignment was fine...just the steering wheel was off center.
GB
Old 01-15-2007 | 09:52 AM
glb's Avatar
glb
Looks to me like you're getting THE DREADED RATTLE!
Old 01-15-2007 | 09:09 PM
  #26
vinney's Avatar
Metallic steering noise
I have the very same problem with my 1LT 2.4 auto. Its a metallic noise mainly when it's cold and putting upward pressure on the steering wheel makes it go away. They have already replaced the steering column once along with the intermediate shaft and replced the steering rack under the car twice. Have you fixed yours yet? and what did they replace? My noise has been there almost since day one but it's a little worse now. any info will be greatly appreciated.
Old 01-15-2007 | 09:17 PM
  #27
Vinney.
Old 01-22-2007 | 09:09 AM
  #28
glb's Avatar
glb
They ended up replacing the steering column; intermediate shafts; and rack and pinion assy. The rack and pinion was the last to be replaced and what finally took care of the problem. Been driving it for about a week now and all seems to be good...so far. One thing though, you've gotta have a dealership that is willing to acknowledge the noise and then be persisitent with GM. Other than the alignment issue with me; I really did appreciate the dealership's persistence. They never gave up. Took them 2 months, but the issue has been resolved.
Good luck.
GB
Highspeedcjb
03-10-2014 05:10 PM
nitro_alltrac
03-27-2013 04:02 PM
hozer
08-18-2012 02:46 PM
MajorSpittle
03-11-2011 05:09 PM
Gol10dr
07-11-2009 08:28 PM
Quick Reply: HHR Rattling sound when driving over uneven surfaces
