hhr wont turn over ??
i drove car on sat worked fine, wife goes to take to church sun morning, she says i turned over,started and quit, now wont turn over, i cked all the battery conections ect , any ideas ????
Check the battery for voltage , check the fuse box under the hood, and the ground wire connection at the front driver's side of the rad cradle then follow it down to the front of the transmission just to the right of the engine below the oil filter cap!
Sounds to me like a dead battery
If I understand correctly the car will crank over only when you jump the wires at the starter but will not start. Im guessing you my have a problem with the under hood fuse box.
Another thing that comes to mind is the anti theft key system. Have you tried a different key
