hhr wont turn over ??
Let's do logic now.
The starter does activate when a hot wire is attached directly to it.
The relay is clicking.
No electricity being sent through the relay? Is there voltage going into it?
If not, why.
If not, why.
Well well well! The ground at the front of the transmission just below the oil filter to the right of the engine block, and follow that wire on up to the radiator cradle , both are 13 mm nuts.
Please double check them. I inspect mine every oil change!
anthonybeatz22
04-13-2014 12:54 AM
Farmers Daughter
03-31-2014 06:09 PM
itschaboykenny
06-13-2008 07:43 AM
