High Beams Not Working. At my wits end
Old 10-04-2023 | 03:02 PM
racejwd357@gmail.com's Avatar
2009 Chevy HHR SS. Both High Beams suddenly stopped working. Replaced bulbs even though I didn’t think it was that. Replaced the full headlight and nothing. Replaced the headlight switch next and still didn’t work. Replaced the high beam relay and then finally replaced the BCM. But they still don’t work. Have had several HHRs but have never run into this issue that nothing has worked. If anyone has any other ideas on what it could be I would greatly appreciate your input.
Old 10-04-2023 | 03:14 PM
High beam relay #72 and high beam fuses #66 and #67 in the under hood fuse box.
Old 10-04-2023 | 04:15 PM
I checked fuses and relay
Old 10-04-2023 | 04:30 PM
You mentioned high beam relay, but not the fuses
Old 10-04-2023 | 08:04 PM
greg8453's Avatar
Where do they get their ground?
Old 10-04-2023 | 09:36 PM
J W Davis's Avatar
Only takes a few minutes to replace the turn signal multi switch, and cheap too. Just saying.......
Old 10-04-2023 | 09:41 PM
Said already replaced the switch.
Old 10-07-2023 | 10:12 AM
And wasted money on a new BCM. High and low share ground points.
Are the fog lights on? No high beams when using fogs.
Old 10-07-2023 | 11:44 AM
Well technically its high beams on will disable the fogs.
Fogs on won’t turn off high beams.
Old 10-07-2023 | 12:02 PM
Since it is illegal to drive with both high beams and fogs, I think you will find that a factory installed fog light will disable the high beams, that is one of the things the BCM programming controls. I can't imagine Mother GM allowing us to do something illegal.
This is what ChatGPT says about it:
Quick Reply: High Beams Not Working. At my wits end
