High Beams Not Working. At my wits end
2009 Chevy HHR SS. Both High Beams suddenly stopped working. Replaced bulbs even though I didn’t think it was that. Replaced the full headlight and nothing. Replaced the headlight switch next and still didn’t work. Replaced the high beam relay and then finally replaced the BCM. But they still don’t work. Have had several HHRs but have never run into this issue that nothing has worked. If anyone has any other ideas on what it could be I would greatly appreciate your input.
Since it is illegal to drive with both high beams and fogs, I think you will find that a factory installed fog light will disable the high beams, that is one of the things the BCM programming controls. I can't imagine Mother GM allowing us to do something illegal.
This is what ChatGPT says about it:
