How do I replace defective yaw rate/lateral accelerometer?
I just got back from my dealer from having the ignition switch/keyset recall performed and had them check why my ESC light was on. They said it was a defective yaw rate/lateral accelerometer code C0292. I've never heard of that! Where is this thing and how hard is it to replace? If it matters I have a '09 1LT. They want $385 to do it for me. That seems awfully high! Help!
I "think" that has to do with the airbag/rollover module. That price sounds right, the part goes for around $300 and then it needs TechII programing. I had to do that when my side curtain airbags deployed in a misguided attempt to save my life (insurance paid).
When it comes to SRS components, I'd skip the used parts and go with new OEM parts. But that's just me, if the parts whopper is referencing are properly tested and certfied, then you can save some scratch.
Remember, these components can save your life in the unlikely even they're ever needed, so you need to quantify budgetary restraints vs. peace of mind.
P.S. to the forum! Wish the circumstances could be better, but let us know how you make out OK.
GM also has an air bag problem. They don't include the HHR but they also tried to exclude the HHR from the ignition and power steering recall. I'd ask to speak to the GM rep and mention taking the issue to NHTSA.
http://www.autonews.com/article/2014...r-airbag-issue
kornellred
02-10-2008 08:58 PM
