How hard is it to change the camshaft position actuator?
Old 11-23-2015 | 09:04 PM
If the CEL light was on, just prior to replacing the solenoids, dont forget that you can reset the CEL by disconnecting the NEGATIVE post on the battery for 5 minutes.
Old 11-23-2015 | 10:03 PM
bugo's Avatar
I removed the battery cable before I changed the solenoid. So far the car is running fine. I have a 200 mile trip coming up in a couple of days so I'll be testing it.
Thanks to everybody who helped. You helped me save $100 if not more. I didn't even know the solenoid existed until I posted this thread and now I have successfully çhanged one.
Old 11-24-2015 | 10:12 AM
Ijazzu's Avatar
Congrates on a job well done!
You are 100% right about disconnecting the battery in the trunk area BEFORE YOU START ANY WORK on your car! Just remember to put a towel over the latch before you let it down.
whopper
"How To" Tutorial Library
633
07-18-2016 01:28 PM
Gsus
02-04-2015 10:58 AM
Ceashure
01-11-2013 04:15 PM
mskitty
02-08-2011 05:06 AM
gascorpion
01-27-2010 03:12 PM
Quick Reply: How hard is it to change the camshaft position actuator?
