Hvac
Old 08-05-2023 | 10:30 AM
ladytopaz11's Avatar
Hvac
I have a 2010 hhr and everytime I use my ac after a while my passenger side floorboard is real wet.
Any ideas
Need Help
How to fix it
Old 08-05-2023 | 10:58 AM
The drain is clogged.
Old 08-05-2023 | 11:10 AM
X2. The AC evaporator box drain is clogged.
Simply unclog it at the firewall with a short piece of weed eater string. If you don’t know how or where the drain is, then take it to a repair shop.
Old 08-05-2023 | 01:27 PM
It’s just to the passenger side on the fire wall
That rubber tube , just insert a piece of weed wacker plastic line, wiggle it about and watch the crud and water drain out.
Old 08-05-2023 | 02:48 PM
I bet the AC air stinks. The big box auto parts stores sell an aerosol product you spray into the vent it foams up and kills all of the nasties that stink and clog the drain.
Probably change the cabin air filter, it is probably from the factory since nobody reads the Owner Manual (link in my sig).
Old 08-28-2023 | 05:59 PM
Ron S's Avatar
Don you forgot rule #4 if it doesn't work get a bigger hammer
BobQ
07-31-2023 07:31 AM
bfreckman
08-10-2022 01:10 PM
Mike Fry
07-24-2020 04:43 PM
hhrCC
09-01-2013 07:49 PM
Quick Reply: Hvac
