HVAC fan speed control only works on high
Old 10-05-2009 | 10:46 PM
sunnyfl77's Avatar
I have a 06 HHR LT and yesterday the round fan speed control knob only works on high, wondering if anybody has run into this issue? Recall maybe? any help would be appreciatted.
thanks
Old 10-06-2009 | 09:41 AM
skyeglen's Avatar
Use the search for "Heator Motor Resistor". Should bring up a thread I started awahile ago that will tell you why you only have the high speed and also show a diagram from Chevy Mgr. where the resistor is located. I got one from NAPA for around $40 if I remember correctly and only takes a couple minutes to put in.
Have you noticed any water leaking in on the Pass side? Probably caused your problem by shorting out the resistor and will need to be repaired or you will have the same problem again.
Old 10-06-2009 | 09:45 AM
ZTony8's Avatar
Genuine GM is $42.19 plus tax. Part #15818910.
padlockbob
06-04-2015 04:01 PM
j4moreno
02-26-2014 05:52 AM
topgunn
06-21-2013 07:51 AM
tkfross
02-25-2010 10:46 AM
JimZ_HHR
02-22-2007 01:04 PM
