I have a weird problem
Old 07-30-2019 | 07:51 PM
Christopher Taccone's Avatar
So my hhr will not start, OBD will not connect to my scanner, windows wont roll up, radio doesn’t work and locks won’t work. Battery is ok. Turn the key to aux nothing. Turn the key to run lights on the ipc come on. Car shut off at a light and that was it. Help
Old 07-30-2019 | 08:06 PM
Welcome.
What year and model/engine and mileage are we talking about?
How exactly do you think the battery is ok?
Old 07-30-2019 | 08:34 PM
Originally Posted by whopper
Welcome.
06 4cyl 313000
Old 07-30-2019 | 08:38 PM
Welcome.
Tested ok by aaa. Does the bcm have anything to do with the dlc not working
Old 07-30-2019 | 08:51 PM
Assuming the battery was tested after this started; check the large red wire connecting to the under hood fuse box, make sure it is firmly attached and cleaned.
Why do you ask about the BCM? Did something happen that you are leaving out?
Old 07-30-2019 | 08:59 PM
Windows, locks, dlc not working. DLC has power.
Old 07-30-2019 | 09:03 PM
So? What are you calling DLC?
The BCM gets it's power from the maxi fuse next to the battery the rest of the car gets it from the aforementioned red cable.
Old 07-30-2019 | 09:15 PM
Data link connector (obd)
Old 07-30-2019 | 09:22 PM
Red cable is tight no play.
Old 07-30-2019 | 09:29 PM
Ignition recall?
Quick Reply: I have a weird problem
