I was running sluggish, but it went away on next start?
Old 07-25-2018 | 03:18 PM
Jpak88's Avatar
So I was driving down some back roads, and noticed the car was behaving very odd. It was sluggish. When I'd let my foot off the gas, it would slow down much more rapidly than usual. It felt like it was shifting poorly as well. And the kicker, when I'd coast down to about 35-40mph, for a moment it felt like the brakes were applying themselves. It all freaked me out really bad.
But then I pulled over, turned the car off and back on, and now it's not doing any of that anymore. Was this some kind of weird car spaz? Should I be worried?
​​Before you ask, yes, the parking brake was disengaged when I was driving. Is it possible that even though I did that it might have been stuck?
Old 07-25-2018 | 03:23 PM
Could be possible, but I’d check other systems, did the CEL come on?
What engine, what transmission, ABS brakes ?
I’m thinking loose ground wires somewhere, or low voltage at the battery.
Old 07-25-2018 | 03:29 PM
Jpak88's Avatar
No CEL. Engine is 2.4, yes ABS, not sure about the transmission. It's a 2006 LT.
Old 07-25-2018 | 03:31 PM
Check the air filter and the throttle body, it might need to be cleaned.
Old 07-25-2018 | 03:39 PM
Cat Man HHR's Avatar
For it to power down as stated? Aren't those items long term problems that add up to a power complaint?
Old 07-25-2018 | 04:30 PM
Yes but sometimes it’s the cause.
Sometimes a battery lobotomy resolves the problem.
Old 07-25-2018 | 05:33 PM
Jpak88's Avatar
A mechanically inclined friend suggested "classic GM electrical issues." he didn't elaborate because he cokldnt possibly know what sort, since it's only happened once and it's already resolved for now. I'm gonna wait for it to happen again and/or just get more frequent so I can better explain the issue to someone who may fix it.
Honestly, I'm about to tow the thing 600 miles on Monday for a big move, after that I'll worry about weird random gremlins.
Old 07-25-2018 | 05:56 PM
As I indicated previously, perhaps a battery lobotomy will clear the issue.
Disconnect the battery negative cable for a full 30 minutes.
This will reset the computers.
Old 07-25-2018 | 06:14 PM
Jpak88's Avatar
I'll try that when I get home. I went and got the battery tested while it was on my mind and for being the OEM in an 06, it's apparently in incredible shape.
Old 07-25-2018 | 06:18 PM
Silverfox's Avatar
Your explanation of the symptoms makes me wonder if you accidentally had the Transmission Shift Lever in "I" instead of "Drive" ??
Silverfox
Quick Reply: I was running sluggish, but it went away on next start?
