Ignition Coil
Old 02-28-2011 | 05:22 PM
ericm1a2's Avatar
Ignition Coil
Best ignition coil for the 2007 and up 2.2l
Old 03-01-2011 | 12:41 AM
not positive if the 2.2 uses separate coil packs like the 2.4, one directly over each spark plug..
IDK about the BEST, but the OEM coil packs are fine in mine.
Old 03-01-2011 | 01:53 AM
TiggersHHR's Avatar
My 2007 2.2 has individual coil packs over each plug.
Early to middle of the 2006 production run had a single coil pack for all of the plugs.
Evidently, during the start of 2007 (also later part of the 2006 production run) GM switched over to individual coil packs.
As far as what would be the best - Good question.
Advance Auto - AcDelco - Part #D517A - $36.09 each - Warranty ???
Advance Auto - BWD - Part #E991 - $99.99 each - Warranty Limited Lifetime
Pep Boys - BWD - Part #E991 - $89.99 each - Warranty Limited Lifetime
RockAuto.com - AIRTEX / WELLS - Part #5C1609 (#12578224, C1552) - $60.79 each - Warranty ??
MyPartsGarage.com - Wells Coil - Part #Wel-C1552-34 $61.79 each - Warranty ??
PartsGeek.com - Prenco - Part #19079-01034494 - $63.52 each - Warranty 2 years
theAutoPartsShop.com - SMP - Part #chehhr/SIUF-491 - $59.12 each - Warranty ??
Old 03-01-2011 | 02:20 AM
Thank You Tigger...
Very interesting..
Old 03-01-2011 | 04:26 AM
ericm1a2's Avatar
Cool TiggersHHR i cant believe the delco is the cheapest
Old 03-01-2011 | 06:26 AM
TiggersHHR's Avatar
The ones the dealer would sell you most likely would be AcDelco as well. If I remember right, GMParts Direct had them for around $40. Check it out - your dealer might even sell them to you for the GMParts Direct price.
Old 03-01-2011 | 06:46 AM
TiggersHHR's Avatar
Just checked mine and yes they are AcDelco.
Old 03-02-2011 | 02:51 PM
ericm1a2's Avatar
I just got 4 new acdelco's off ebay for 99$+18 s/h
Old 03-02-2011 | 02:54 PM
urbexHHR's Avatar
I would think it would be better to have the singles, that way if one goes bad you don't have to replace them all...
Old 03-02-2011 | 03:27 PM
ericm1a2's Avatar
Yup i have the single coil pack
Quick Reply: Ignition Coil
