Ignition Problems
Ignition Problems
My 2007 HHR is sitting dead in a parking lot. I've replaced the starter, alternator, battery and ignition coils (4). All it does is click once when I turn the key. I'm running out of patience. Does anyone have any other suggestions as to what may be wrong? Has anyone else had this problem? Your help will be greatly appreciated!
Welcome to the site. Give me some info on what led up to you being in the parking lot. Was you driving and it stalled? Did you come out and it just wouldn't start? Any weird things happen before this no start condition?
If you have an auto club membership, you may want to have it hauled to your dealer or a mechanic.
Unfortunately, due to the complexity of the HHR's interrelated electrical components and control modules, it's time to call in the cavalry. Plus a technician can connect your vehicle to a Tech II scanner and interrogate its systems for stored trouble codes if any exist.
And a bit more background info would be super helpful as Lucky has already pointed out.
P.S. to the forum, sorry about the circumstances though.
Yeah. Need some more history/info.
Fwiw. I would check the voltage at the starter before and when you try to start it.
Another easy check is the main power connection at the side of the underhood fuse box. There have been other posts on this site about the connection coming loose or breaking off.
shybull
GM Recall Campaigns
43
12-22-2014 10:02 AM
Cokeybill
GM Recall Campaigns
08-19-2014 09:42 PM
Benjamin
12-04-2012 04:19 PM
