Ignition stuck in run position, had to pull fuel pump fuse...
Old 05-05-2014 | 11:02 AM
Augmented78's Avatar
So, yesterday I attempted to shut off my car and found the ignition locked in the run position. After attempting to shut it off for 10 mins I pulled the fuel pump fuse to kill it. After, I disconnected the battery so it wouldn't drain overnight, which wound up being a headache climbing through the backseats to reconnect it today. Now, when I try to start the car the console is saying "ENGINE POWER REDUCED/ENGINE DISABLED". Any ideas what to do to fix this?
Old 05-05-2014 | 11:09 AM
I'm assuming the Check Engine light is on??? What is the code downloaded from the OBDII system?
Old 05-05-2014 | 11:13 AM
and a quote from an old posting about releasing a stuck key:
"Page 2-22 of owners manual describes removing small plastic cover
(Approx. 3/4 " square) from the bottom of the steering wheel housing and pushing a small button towards drivers side, should release key, two handed operation.
Also had same the problem with a Cobalt (same set up) shifter button became stuck in the depressed position. A little coaxing released it also."
Old 05-05-2014 | 11:33 AM
I tried that and it would not release the key....
Old 05-05-2014 | 11:34 AM
Haven't made it that far yet....car is sitting in my driveway and I don;t have a reader on hand. I've called the local GM dealership since my vehicle should be covered by the ignition recall. Waiting for the service manager to call me back.
Old 05-05-2014 | 12:39 PM
prod's Avatar
Sounds exactly like mine last year. Got the ignition switch replaced and all was well. Not sure about the codes though.
PhatBob
07-24-2013 02:30 PM
dlmhhr
05-31-2012 02:55 PM
ggoneprr
12-22-2010 07:50 AM
Klifnote
03-09-2008 07:16 PM
Quick Reply: Ignition stuck in run position, had to pull fuel pump fuse...
