I'm about to pull my hair out!!!!!!
Old 10-10-2019 | 05:56 PM
You can get them a lot cheaper than $300. The 13.9 while running is a bit low, usually 14.3 but varies.
Old 10-10-2019 | 06:47 PM
RockAuto gives us a discount
https://www.chevyhhr.net/forums/supp...-2019-a-61707/
Old 10-17-2019 | 01:10 PM
dblsprt1968's Avatar
PROBLEM SOLVED!!!!!!! Thanks for all the help on this issue. The fuel pump module had two things wrong with it. First it would not hold pressure in fuel line, and second it would produce only half the amount of pressure needed. I dropped the tank, swapped out the pump. I took the exhaust loose from the mounts, but did not unbolt it. Put it all back together and had my gauge on the fuel rail. Fantastic holding pressure :) Started right up!!!!!!!!!!!! :) :) :) BTW, I bought the Delphi pump. Plug and play!
Old 10-17-2019 | 01:52 PM
Awesome, news! Enjoy the drive! Now give it a good wash and vacuum, and you’ll be ready for winter!
RobPerdue
05-09-2012 11:24 PM
Dragbike1
08-15-2008 09:20 PM
chevcat
05-01-2008 10:25 PM
GDZHHR
08-03-2006 06:51 PM
Quick Reply: I'm about to pull my hair out!!!!!!
