Injector removal / installation
Old 01-01-2013 | 08:34 PM
BaxterBear's Avatar
My 2006 2.4L, 103k, is throwing code P1174. I have searched alot of threads related to this and see it is most likely an injector issue requiring replacement. I am not seeing any other codes such as P0300 as others note, so I don't know what cylinder. I do notice an occasional skip/misfire even though it doesn't throw a P0300. It looks like I will most likely replace all, as I noted somewhere that GM has replaced this part with an upgrade along with an ECM update, so...... I can't seem to find any posts related to the actual process of removal / installation of the injectors. Does anyone know if one exists? BTW - My car is also due for new plugs and will be replaced later this week. Any chance this could be the source of the code vs injector problem? I might be hoping for too simple an answer, but thought I would ask. Thanks for any help you can give!
Old 01-01-2013 | 10:47 PM
I would try the plugs first. If it clears it up, then great. If not, then you can go the injector route.
Old 01-02-2013 | 06:05 AM
BaxterBear's Avatar
Thanks for the reply Fireman. Keeping my fingers crossed! I really don't want to get into the injectors if I don't have to.
Old 01-02-2013 | 07:55 AM
SmootHHR's Avatar
I'll be doing the same shortly. Need to order them first.
Old 01-02-2013 | 08:00 PM
alexrckid's Avatar
http://arrc.ebscohost.com/searches?c...trol%2Fgeneral
Old 01-02-2013 | 08:04 PM
alexrckid's Avatar
Old 01-02-2013 | 08:06 PM
alexrckid's Avatar
Old 01-03-2013 | 03:40 PM
plugs first the AC Delco's are a good choice
Old 01-03-2013 | 05:00 PM
Snoopy's Avatar
alexrckid......
Whatever you are trying to do (from yesterday), is not working. All that is displayed, when clicking the link you provided, is a sign in page asking for I.D. and Password for some website.
Must be important though......you tried and posted 3 times without success.
Old 01-05-2013 | 08:23 PM
alexrckid's Avatar
try p/w pl249412345678
Quick Reply: Injector removal / installation
