Intake duct question
Old 05-03-2011 | 10:50 PM
wesbalmer's Avatar
Can someone please post an image of their actual intake duct. I have a 2007 LT2, if that matters. I was replacing my air filter today when I noticed that this part was a fabric breather hose that completely fell apart after moved it. I'm looking to replace the part, but if it is meant to be a fabric breather hose like it was, I'll just replace it with like material and the included fittings. Refer to part number six in the following image
Old 05-03-2011 | 11:02 PM
The woolly worm, is a fabric corrugated breather hose, somewhat thicker material than most.... Odd yours self destructed, My '07 piece looks like new.
Old 05-03-2011 | 11:06 PM
wesbalmer's Avatar
Thanks! It doesn't seem worth 65$ to replace with a new factory part as most of the cost probably comes from the fittings on each end. I'm going to head over to Home Depot or somthing to find the correct type of hosing.
Again, thanks for the quick answer. I'll post pics of the new hose when its complete. Since I found absolutely nothing on Google about this, and it seems it could easily happen again, maybe I'll help out the next guy.
Old 05-03-2011 | 11:09 PM
I'm thinking his woolly worm is a victim of the Arizona heat, they see some really elevated under hood temps out that way. It may also be a victim of the dry climate out there, might have dried it out so it lost its ability to flex.
Old 05-03-2011 | 11:24 PM
wesbalmer's Avatar
I wonder, for future reference, how could someone take care of that hose? Like you said, the elevated under the hood temps must have heated up the adhesive to the point where it could mix with dust particles.
Another question, is this hose a crucial part of the intake system? Seems like the placement doesn't allow for adequate flow. Thinking about it, I'd like to route something closer to the lower grille.
Old 05-04-2011 | 12:49 AM
The "wooly worm" is important to inhale outside air from behind the inner fender.. It is actually very efficient.
But you can use the search box & see how others have customized theirs.
Old 11-16-2014 | 12:29 AM
jettstar's Avatar
The same thing happened to my wooly worm today. Did you post the pics of your finished hose? I'd like to see it and know how you fixed it. Thanks!
Old 11-16-2014 | 01:54 AM
3+ year old threads are not usually going to get a response from the Original Poster, Wes's last visit here was on August the 7th, 2012.
But here's some info for you.
The GM part number is 15865168, list price is $81.67
These folks have them for $51.94 +Frt.
Add to Cart: 15865168 DUCT
You might also check at RockAuto, or give reparing it a shot with duct tape or Gorilla tape.
Old 11-16-2014 | 02:15 PM
I wrapped mine with metallic duct tape (not Duck tape).
Old 08-02-2015 | 10:24 AM
SixPak's Avatar
Wooley Worm Air Duct replacement
Oreilly Auto Parts = 3" Air Duct for about $20 and it works well. Just have to use the end pieces from the original duct.
lafinests213
2.4L Performance Tech
08-06-2012 08:21 AM
new to bowtie
17
12-21-2010 03:08 AM
joesblackhhr
13
08-25-2006 08:49 AM
