Interior fans only work on high and theres a burning smell
Hello, I have a 06' HHR.
The interior fans only work on highest setting. Also there is a burning smell when using the fans. What could it be? Thanks
This thread should help you out, also make sure you don't have water leaking in, its a known and common problem on the 2006 model year.
https://www.chevyhhr.net/forums/show...t=Blower+motor
Just a quick question as I am about to go purchase this part and install it myself when I get home.
Do I need to dis-connect the battery or any electrical components before I uninstall the old and install the new "heater motor resistor"? As to not fry anything or get electricuted, thanks.
If you think you could get electrocuted - I really don't feel comfortable suggesting you disconnect the battery in case you short the battery out with disasterous results. Nor do I feel comfortable saying just replace it, ensuring the vehicle is turned off (with the key out of the ignition).
I'd suggest you take it to a dealer and have them install it. A 5 minute job.
LuckyLadySD
06-12-2014 02:09 AM
