Interior Passenger Door Handle
So it seems the handle to open the door from the inside is broken. The door can be opened from the outside just fine. The interior handle seems a bit loose. I haven't removed the door handle to see what's going on...its a tad cold. But would any of you know what the problem may be? I'm putting together an order from Rockauto and didn't know if that was something I needed to order from them.
Thanks for opinions and suggestions...
Ronnie
Ronnie
These handles are plastic and break often.
It's usually the piece that connects to the cable.
There are some that are metal and are the recommended replacement.
They are also quite easy to replace.
I know as I have done it.
I have replaced the exterior handles but not the interior. Thanks for the info!
Would you happen to be affiliated with Hells Gate Hot Rod?
Oh! It looks like this is my problem and I am not receiving messages.
Now I checked it again - there is nothing, although there is free space.
I read that you have already bought the handle. But if you want, I will send you this as a gift. The offer is still valid.
