Intermitten Power Steering issue
Old 12-08-2016 | 12:23 PM
le2007will's Avatar
My 2007 HHR LT will periodically show power steering in the display & I have no power steering. I found that I can stop, turn off, & restart; power steering is ok. May not do it for a month. As far as I can find there is no recall for the steering for my year model but there is for the 2009 - 2010. So far all my research seems to point to steering motor under the dash but could be the steering module. From what I have read the dealer isn't much good at finding the problem, they may replace the motor, then replace the module, and finally replacing the steering column & i'm not wanting to spend a fortune for that kind of service. Anyone have any ideas?
Old 12-08-2016 | 12:52 PM
No recall.....HOWEVER there is an extended warranty for the life of the car all years.
In other words, you have to ask for it. And hopefully you did save the letter from GM that was mailed to registered owners a few years ago.
Have the ignition recalls been done?
https://www.chevyhhr.net/forums/gm-r...tension-50057/
Old 12-08-2016 | 01:00 PM
As Don states, you have to show the dealership that you have this problem.
Old 12-08-2016 | 01:07 PM
Yeah, you should have gotten, and saved, that letter from GM... Also at the time you are at the dealer the power steering will need to be out or you may get the "can't replicate customer's concern" blowoff. (depends on the dealer I guess)
Old 12-08-2016 | 01:50 PM
le2007will's Avatar
Thank you for the replies. I don't have a letter about an extended warranty, bought the car Dec 2014. I did get the ignition recall letter & got that fixed. So far the steering issue is intermittent & whenever you turn the ignition off, it resets & works fine. I'm going to try the motor replacement, check fuses & relays. If it gets to where it won't reset then I guess I'll try the dealership.
Thanks again.
Old 12-08-2016 | 05:52 PM
Try the dealership first, explain the problem, the steering issue is fully known to be intermittent.
Old 12-08-2016 | 08:33 PM
See the post directly above, he done took the words right outta my talking hole.
Tarry not, and get Thee to yon Dealership post haste.
Old 12-11-2016 | 07:17 AM
J W Davis's Avatar
Drove ours over to the local dealer and he said "no problem'. I sat in the waiting area for about ten minutes and it was replaced...no charge. I had the letter though.
brazor06
12-11-2022 07:59 AM
allij0812
12-12-2013 11:16 PM
Fred Watton
04-04-2013 11:33 AM
uglyjim
07-16-2011 01:56 PM
Quick Reply: Intermitten Power Steering issue
