Intermittent Hard Starting When Warm
Old 06-23-2012, 05:15 PM
Dyke67ny's Avatar
Recently, my 2006 HHR LT began exhibiting difficulty starting when the engine is either hot or just sat for a couple of hours after running & not being completely cold. When the engine is cool, it starts right up.
I just replaced the fuel pump as 1 of the threads on here showed many HHR owners suffering the same problem of the intermittent hard starting when warm only to be corrected after replacing the fuel pump.
The problem still exists...
Also, I replaced the battery.
Any suggestions on what else I can check?
Any help would be greatly appreciated.
Dyke67ny is offline
Old 06-23-2012, 07:06 PM
How many miles on it? When were the sparkplugs replaced last? No CEL lit?
whopper is offline
Old 06-23-2012, 08:20 PM
Dyke67ny's Avatar
67,400 miles & no, I have not replaced the plugs.
The car performs great when its already running or when its cold out. Its only hard starting when the engine is hot but after a few attempts it fires up normally with no further issues until you go to restart it after its been running for awhile...
This problem just started a couple of weeks ago...
Dyke67ny is offline
Old 06-23-2012, 08:22 PM
Dyke67ny's Avatar
no CEL is lit nor are there any soft codes...
Dyke67ny is offline
Old 06-24-2012, 03:56 AM
I've had similar issues with a tank of bad gas - and also with heat-soak on an early Fuel-injected Volvo due to the Bosch FI. I've also encountered it with a particular brand of gas that I won't mention (Shell) years ago, and now I will push my car to a gas station rather than use that particular brand. :-)
With the low mileage on the car, could it be it has been happening on the one tank of gas since it has only been happening for a couple of weeks?
The plugs don't owe you anything - I'd change them out and see what happens.
whopper is offline
Old 06-24-2012, 07:33 AM
Hmmm...well my first thoughts mirrored whopper's "heat soak and vapor lock", but that just almost never happens on "modern" vehicles.
No codes knocked my second thought about cam sensors/actuators off the table at least for now, but not entirely.
A tank of bad fuel may be the cause, have you changed gas stations lately?
Throwing plugs in 30,000 miles "early" can't hurt, but are they the cause, probably not. And make sure if you do change out the plugs, use the proper AC Delco ones, Ecotec engines are known for not liking other brands.
I'd take it somewhere to have your fuel pressure checked when its cold, and then after getting it up to operating temperature, you may have a failing pressure regulator.
843de is offline
Old 06-24-2012, 07:58 AM
Dyke67ny's Avatar
Where is the pressure regulator located? I had thought it might be part of the fuel pump assembly as those who had the same issue as mine, replaced the fuel pump only to have it correct the problem.
As for gas (vapor lock was considered too), I would not think it would just cause a hard start when the engine is hot & then not have any other issues. Will fill it with different gas today either way.
I've also been thinking of a possible sensor since its only when hot.
Dyke67ny is offline
Old 06-24-2012, 08:22 AM
The fuel pressure regulator is part of the fuel pump module, and replacement of the entire fuel pump is the recommended procedure when fuel pressure regulation becomes erratic. Can your new fuel pump have a bad regulator, yes, is it terribly likely...no...but a check of fuel pressure is still something to think about.
If you can shoot me a PM with your e-mail address, I can send you the troubleshooting section of the 2006 factory service manual in PDF form. Do you have a 2.2 or a 2.4 in your LT?
843de is offline
Old 06-24-2012, 08:48 AM
Dyke67ny's Avatar
2.2 liter.
Did you receive my pm as it said there was a problem posting.
Dyke67ny is offline
Old 06-24-2012, 08:49 AM
Got your PM, e-mail is on the way. Just ignore my PM, you posted here while I was typing there so its redundant.
843de is offline
Quick Reply: Intermittent Hard Starting When Warm
