IPCW L.E.D.'s issues...
Old 06-12-2008 | 08:29 PM
Digital_Rapture's Avatar
Exclamation IPCW L.E.D.'s issues...
OK, so all of a sudden my climate control panel, moon light and gear shift panel don't light up. Checked out the Tail lights... turn signals, reverse and brake lights are fine but the running lights aren't on... has anybody ran into or know about this issue???
Old 06-12-2008 | 08:31 PM
xzombiex66's Avatar
this should have nothing to do with the tails, check your fuses.
Old 06-12-2008 | 08:32 PM
xzombiex66's Avatar
Also make sure you didn't mash a wire when screwing the light in and cause a short which will blow your fuse, i think its the number 13 fuse.
Old 06-12-2008 | 08:37 PM
Fuse 13... check. My parking lights and lisence plate isn't comming on either... I'm not sure what may of caused it though because I was careful not to pinch any wires and they were working fine yesterday and today... I'll see what I can find.
Old 06-12-2008 | 09:37 PM
mudd274's Avatar
Hey Digital,
slow down on the mods, you are are blowing the hhrs mind.
just kidding!!!!
do what chad said and check the fuses.
Hope thats the problem. If not you are gonna have to check every wire that you have fooled with in the pass day or so.
good luck
Old 06-13-2008 | 08:57 AM
Interior fuse panel....................Airbag
Under hood fuse block...............Fuel Pump
Old 06-13-2008 | 09:01 AM
xzombiex66's Avatar
yea i already told him i wasn't positive, it was fuse number 69, thanx.
Old 06-14-2008 | 07:34 AM
Well I doubled checked the install and nothing was pinched. I also double checked 2 make sure "black" was to "black" as per instruction. Those were the only wires I have messed with. I then went and got some wire bundle tubing and put it around the wires that go from the top to bottom LED 4 added protection... I ran the parking lights all day and no issue. I'm keeping my fingers crossed that it was just some sort of flukie or something...
THANKS CHAD & DEBBIE!!!
LuckyLadySD
06-12-2014 02:09 AM
skyline26
03-23-2013 04:56 PM
ChevyGuySS
05-09-2011 10:33 AM
sanmn420
Mods - Exterior
30
03-22-2011 08:08 PM
Michael20832
North East
01-06-2010 12:13 AM
Quick Reply: IPCW L.E.D.'s issues...
