Jack stands
Jack stands
I have jacked up my HHR at the correct lift point as high as my floor jack will go but it is not high enough to get a jack stand under the frame. I am using a pretty standard hydraulic 2 ton floor jack and jack stand. Do HHR's require a short jack stand?
I went to the local sports supply store and bought a pack of hockey pucks. sometimes 1 is enough if 2 are needed I screwed 2 together and glued them.
They are really cheap a bag of them cost about $5.
I found a good place for the stands is where the front horns flatten out. The rear is a big challenge.
