Jumped HHR the wrong way...
So I connected to the positive and then to the bolt with the red cover on it...(it was dark and I didn't realize it nor did i bother with the owners manual. so I Blew the 60 amp EPS fuse. Auto Parts Stores are closed so I haven't replaced it but I am wondering if that is usually all you do OR if you get more damage with this mistake. I didn't emmidietly realise what I did. Until I went to "get a better connection" because it was not starting. so it stayed on o good 5 minutes.
Thanks for the info! I checked all the other fuses just in case they are all good. I replaced it and its working like a charm. No problems so far with the auto start and I don't think I have TPMS so I should be ok.
davidhhr06
06-24-2014 05:18 AM
