Just a Few Issues!!!!
Gas gauge still reading wrong, Noise in the front when cold is back again, Still having a stale smell when AC is turned on, and now I noticed my driver side headlight has like a yellow tint to it.
chadpuska, sounds like you have condensation in your headlight . Did a quick internet search and it seems everyone keeps mentioning moisture as the problem for discolored, yellow headlights. No idea if its covered by your warranty...but why not talk to your dealer and find out? good luck!
Yes chad, moisture. It's a common sight on some older cars with original headlights. Your HHR isnt very old tho.....so all i can say is think positive and go over all the things that you'd like fixed under warranty. ALSO, mention how your next new car might be the SS HHR and how good it would be of them to keep you as a satisfied customer.
One of my headlights is more yellow than the other but that is because I use Silverstars and had to replace one of them....you can see the difference when shining on my garage
Have you tried putting a new bulb in?
Goose
Goose
