K&N Intake causing check engine light to come on...
Old 11-27-2012 | 11:34 AM
solman98's Avatar
Originally Posted by chefhhr
The first time was at Shell...this past week was at the BP by my work. Both times was 93 and the cel came on shortly after fill up.
Though maybe it might be the station, but you've got 2 different locations. When they ran the code, what exactly was it?
Old 11-27-2012 | 11:56 AM
chefhhr's Avatar
You know he didn't even tell me the actual code number, he just gave me description on the reader which was fuel rich. I installed my k&n back on too buy he said it wasn't reading an air problem so who knows, maybe between the extra air from the intake with the 93 octane it's throwing a cel. It's just kinda weird that I didn't start having any problems until I started running 93 octane fuel and I've had my K&N since September.
Old 11-27-2012 | 12:15 PM
07azhhr's Avatar
The MAF is directly related to fuel being too rich or lean. It is one of the sensors that the ECU uses to determine how much fuel to inject into the cylinders. It can still be your issue but seams odd that it would be unless you have ran your K&N on there again with too much oil on it.
Old 11-27-2012 | 12:20 PM
chefhhr's Avatar
I've had my new K&N installed since September...threw my first cel in November. I'm thinking if it was going to throw a cel it would have thrown it sooner. It's funny too because my cel goes off after a day or two of running on the new gas. Car runs fine otherwise.
Old 11-27-2012 | 12:51 PM
solman98's Avatar
Maybe you should try cleaning the filter and reoiling. I have a recharge kit if you need one.
Old 11-27-2012 | 01:02 PM
  #26
chefhhr's Avatar
Out of all the K&N's I've ever owned I've never had to clean and reoil one. Pretty easy to do I guess?
Old 11-27-2012 | 01:38 PM
  #27
solman98's Avatar
Especially since it practically new. Spray it down with the cleaner, rinse, once dry, reoil. The newer kits have a spray for the oil verses the older dropper style, which many overoiled using. Quick mist with the spray and let it sit. I always give them a good shake before install. I've never had an issue.
Old 11-27-2012 | 01:42 PM
  #28
chefhhr's Avatar
Cool, I'll try that. I'll pick up a cleaning kit this weekend and give it a go.
purple people eater
09-17-2016 01:07 PM
flooprigger
08-04-2013 08:58 AM
jmpnjoe86
03-10-2013 06:13 PM
KenpoWay
02-05-2012 10:08 AM
BigMOCats
10-04-2009 01:39 AM
Quick Reply: K&N Intake causing check engine light to come on...
