key fob = lock set
Old 10-01-2013 | 08:23 AM
kingkat4's Avatar
key fob = lock set
Howdy
When we had our lock cylinder replaced [ got reimbursed ] did they have to take the key fob apart, to reprogram? It doesn't work now, the battery hold down clip is broken loose.
thanks KK4
Old 10-01-2013 | 08:51 AM
common issue , easy to solder back together, use the search for a how to, and no I don't think they would have had to open up the key fob apart
Old 10-01-2013 | 09:51 AM
Maybe the dealer was "helping" by checking the battery in the fob, but that kind of help you don't need.
Here's the thread on fixing the solder joints......
https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
Old 10-01-2013 | 08:07 PM
No, they don't have to take the fob apart to program. But they may have "checked" the battery and exposed the broken bits, the case sometimes will hold the cage down after it has broken loose, open the case and boom.
chonface
07-02-2012 01:26 PM
Geoff
09-08-2009 04:41 PM
Geoff
04-28-2009 12:58 AM
Digital_Rapture
06-22-2008 01:30 AM
Chevy SS
06-18-2008 12:51 AM
