Key Fob Broke
Old 12-12-2009, 06:32 PM
joshua_arndt's Avatar
Key Fob Broke
Both of my key fobs have broke. At first i thought the batteries were bad, so when i went to buy new batteries, and took apart the key fob and found the metal clip that holds the batteries to the key fob was broken off on both of them. Can i just buy new ones off of ebay and program them myself?
Josh
joshua_arndt is offline
Old 12-12-2009, 06:34 PM
oneton's Avatar
There is a post on here on how to fix them. I'll look
oneton is offline
Old 12-12-2009, 06:38 PM
oneton's Avatar
Here it is
https://www.chevyhhr.net/forums/show...ghlight=repair
oneton is offline
Old 12-12-2009, 07:12 PM
xzombiex66's Avatar
mine also did this luckily i was still in warranty, so they replaced mine.
xzombiex66 is offline
Old 12-12-2009, 08:54 PM
Comfortably Numb's Avatar
Will keep comments to myself. Will keep comments to myself. Will keep comments to myself.
Comfortably Numb is offline
Old 12-12-2009, 09:22 PM
Pizzaman's Avatar
If you aren't real handy, Radio Shack can usually repair it quickly. I had to replace my battery, and I went to my local RS and when we opened it mine was broke as well. He soldered it in a jiffy for free. My solder set was deep in the garage, so it worked well for me.
Pizzaman is offline
Old 12-12-2009, 10:11 PM
Lucky's Avatar
I had to repair both of mine and both of then on my dads car. I like the idea of repairing them because more than likely new ones would fail after a year also.
Lucky is offline
Old 12-17-2009, 04:52 PM
Josh
The short answer is NO you cannot program it yourself, unless you have a Tech II scanner a know how to use it. A new fob will run about $100 and programming will be what ever the dealer charges for minimum shop time (probably $79 or so). Resoldering is not difficult, but delicate work. I have fixed three now, the problem is not isolated to GM.
donbrew is offline
Old 12-18-2009, 10:00 PM
xzombiex66's Avatar
Its funny cause my dad has a 98 gmc jimmy his hasn't stopped working since he bought it.
Old 12-20-2009, 11:33 AM
hhrMama's Avatar
I would hit a buddy up to fix it for you if you cannot as this is a very common problem. The hubs has had to fix one of mine before. It stinks you cannot program these yourself since you can on alot of vehicles.
hhrMama is offline
Quick Reply: Key Fob Broke
