Key Fob Issue
Old 02-27-2011 | 11:45 AM
stanvalp's Avatar
got our used hhr 3 days ago. one of the fobs wasn't working. had to resolder the batt hold down. i think the reason for solder connections coming loose has to do with manufacturers using lead free solder. it doesnt seem to be as strong as old leaded solder. xbox motherboards have had same issue.
Old 06-25-2011 | 05:53 PM
JJBoxer1's Avatar
I just got my FOB back, and it work fine, he re solder the battery holder clean the board, and put it in a new case, cost me $18.00, I found him on ebay this is his addy if you want him to repair your FOB,its called Midwest keyless www.ekeylessremotes.com, and their phone number is 815-675-0404.
Old 06-25-2011 | 08:45 PM
Lucky's Avatar
after i resoldered the remotes I had one that the lock button would not work I found this repair kit and it work great. Its keylessfix.com cost 10.00 Its just plastic and sets ontop of the circut board and restores the contacts.
Old 07-07-2011 | 02:05 PM
JJBoxer1's Avatar
E-Z both of my fobs broke to, you can try to solder them back to see if it would work, and it son't need to be reprogram they will work, but I sent my fobs to this place I found on Ebay called Midwest keyless, it cost me $36.00 for both of my fobs to be fix, I got them back and they work great, he do a pretty good job, he replace the old case, the pad, cleaned the board, and solder the battery hold back, took about a week, good luck.
Old 07-07-2011 | 02:32 PM
diskullman's Avatar
I can't solder to save my life, so, one night while stuck in traffic, I was stuck in front of a small electronics repair place. Guy soldered it back to together, put in a fresh battery, while I waited. It took 5 minutes, charged me $5, gave him $10.
Old 07-07-2011 | 07:09 PM
chula52.1's Avatar
I had one fob stop working and the other was intemittant. When I opened the fob both had broken solder joints. I resoldered them and all is well 90,000 miles later. I bought my 2007 HHR used with 48,000 miles on it and it now has 138960.
Old 07-07-2011 | 07:12 PM
chula52.1's Avatar
I had one fob stop working and the other was intermittant. When I opened the fob both had broken solder joints. I resoldered them and all is well 90,000 miles later. I bought my 2007 HHR used with 48,000 miles on it and it now has 138960.
Old 07-07-2011 | 10:23 PM
mroney's Avatar
Keep in mind it is not always just the solder joints. I resoldered mine and it still didn't work. The contacts on the rubber pad looked worn, so I replaced that (about $8 on ebay). It worked fine. So before you get it reprogrammed, with the fob open close the contacts on the pc board gently with a small screwdriver. If the locks work replace the rubber contact pad. You don't want to waste money reprogramming if it doesn't need it.
can2blue
07-11-2013 03:34 PM
Thisstrangeengine
08-30-2011 11:39 PM
gmdealerguy
05-22-2011 01:25 PM
LewiSS
10
10-08-2010 01:29 AM
gcsd3742
07-25-2008 11:10 AM
Quick Reply: Key Fob Issue
